Madcap Restoration 7 years 11 months ago #38767
  • jsp
  • Being nuts is NEAT!
Just noticed the non-stock towers too, where did you borrow those from ?
Madcap Restoration 7 years 11 months ago #38770
Hello
Great Post :y:
I have just finished a Vintage Madcap restoration :P
I like this car :laugh:
Some pictures
Pascal
:woohoo: Nice resto Mate! FRP shocks posts :y: From astute? dyna storm? ;)
Madcap Restoration 7 years 11 months ago #38784
So, i did a test run and the thing is doing so crazy gear noise and cant pull enough power to move more than 4 inches.
Any idea what I could have done wrong??
Thanks,
JS
Have you tightened the grub screw in the pinion gear to the motor shaft? Completely meshed the pinion to the spur gear?
Madcap Restoration 7 years 11 months ago #38789
Sounds like diff or clutch slipping.
Madcap Restoration 7 years 11 months ago #38790
Hello
THANK YOU for your comments :y:
Some precisions concerning this restoration
My Mad Cap if full original but with following upgrades:
- Tamiya 9405673 Press Parts Bag Super Astute (Shock Towers and Metallic support Motor)
- All Bearings
- Two blue metallics Shock absorbers pairs (Front and Rear)
- DF01 Wing Support (replace original MadCap wing support)
- Original Dynastorm Pink Actuo Motor
- Paint : PS-49 Sky Blue Anodized Aluminum (first coat) and PS-5 Black for the second coat
Pascal
Last edit: by sqfab.
Madcap Restoration 7 years 11 months ago #38874
  • jsp
I will check this again to make sure, did put the pinion a while back, did not verify how tight it was the other night :)
As for the mesh, it was a little tight and thaught that was the problem, i will adjust this as needed after checking the pinion screw.
Madcap Restoration 7 years 11 months ago #38875
  • jsp
The only thing i did not disassemble was the diff, maybe i sould take a look in there :(
Madcap Restoration 7 years 11 months ago #38877
Think the Madcap has the same diff as the Monster racer, not known for its trouble free performance. :pinch:
Madcap Restoration 7 years 11 months ago #38879
  • jsp
is there anything specific i can do to fix that trouble free performance? ;)
Madcap Restoration 7 years 11 months ago #38880
:( the diff, gearbox, are the same as the monster racer and the kingcab. I only broke the motor support on my madcap. Changed with an aloy one (same as the astute and the kingcab) never had any problem with the madcap but I had à king cab wich had the transmission full bloked...
Time to create page: 0.190 seconds
