Toyota Tom's RM-01 wheels vs. vintage? 10 years 9 months ago #23011
Has anyone tried a complete rear end transplant from the new RM01 to an old RM MK.5 or MK.7 chassis? I've got a 956 that is missing half the rear axle and the spur is pretty sad.
Don't have a RM (of any age) myself but I did notice the vintage car has a 5mm axle while the RM-01 uses 6mm.
So that would have to fit through the hole in the gearcase at least (and a 1060 instead of 1050 bearing should be used)...
Edit - I reckon you mean a rear axle and diff parts transplant because the gearcase itself won't fit.
Toyota Tom's RM-01 wheels vs. vintage? 10 years 9 months ago #23013
Yes, exactly. The complete rear axle, diff and wheels using the original rear housing.
Looks like it might be worth a try. I'll update once I find all the parts needed.
Last edit: by ap6318.
Toyota Tom's RM-01 wheels vs. vintage? 10 years 9 months ago #23014
Yes, please report back if it works because a definite answer would be great to know. :y:
I suspect both gearcases have the same width (might be worth trying to verify though), as well as length of the axle.
The latter I think because the bodies have the same width.
Besides that, motors rear plates are placed in the center on all RM cars. And not with offset like the later F cars...
My guess would be you could match the bits.
Toyota Tom's RM-01 wheels vs. vintage? 10 years 9 months ago #23016
I'm doing some more research when it comes to axle offset at the moment...
Toyota Tom's RM-01 wheels vs. vintage? 10 years 9 months ago #23017
And yes... they did do the offset thing like on the F chassis cars. An early chassis plate looks symmetrical :
An RM-01 lower brace has an offset (to center the motor) :
That means you'll run into some trouble with left and right spacing...
A challenge I would like to figure out myself as well though.
Toyota Tom's RM-01 wheels vs. vintage? 10 years 9 months ago #23018
Not just some trouble... looked a little more and don't really see how you can make that work. :(
Biggest issue is that the spur will not be in the right place. And/or the motor axle won't be long enough.
On Group Cs and F cars there's a work around for the difference in offset because the gearcases are mostly identical...
Toyota Tom's RM-01 wheels vs. vintage? 10 years 9 months ago #23052
Thank you so much - you just saved me about $100 in parts I would never use. :S Looks like I'm back of the hunt for the old vintage parts. At least I can use the wheels :laugh:
Toyota Tom's RM-01 wheels vs. vintage? 10 years 9 months ago #23053
Glad you didn't order any parts on account of my earlier post. :whistle:
The rear lower brace of the RM-01 looked very symmetrical in the perspective of the manual...
A good alternative for a rear axle would be to make one yourself.
Could even be carbon if you like (don't inhale the dust though).
B)
Toyota Tom's RM-01 wheels vs. vintage? 10 years 9 months ago #23058
HI!... If you good on a lathe you can make a aluminum adapter to run any spur gear you want. That's what I'm in the process of doing currently. Mine will be set-up for Traxxas spur gears since every LHS has tons of these around here.
Toyota Tom's RM-01 wheels vs. vintage? 10 years 9 months ago #23059
Awesome, that's some serious modifying. :y:
Time to create page: 0.204 seconds
