Not sure Lars. The msc hasn't the glas fuse. But I can't exactly be sure.
Is it the aly chassis on the cs?
Lars you were right. It is not a 58012. It is a 58010. with a big motor. The CS has bearings (and the foam tires) not mine. It was just upgraded.
Last edit: by stingray-63.
You should be happy!
The older the better in my opinion
I am realy happy with it. I just dislike my identification error
Thanks Manu. I will try to have the same result than with the Tyrrell. the base is very good but needs a full stripping and new decals.
Wich color can I use for the body? Is it better to only use clear like did Lars?
Thanks for your advices guys. |
Hi Flo, so in the pictures that is just the original plastic colour with the stickers on top ?? I'd have thought it would depend on whether the colour is still even once you have cleaned it up and removed everything off the shell. Lars car came up a treat just clear coated. So it would be tempting to try that.
Good luck, but looking forward to seeing this restoration.
