i'll mainly use it on-road i will also use it off road though
i am looking for upgraded drive shafts aswell update won't get the chunky tires there isn't enough room on the arms. instead i will be getting these |
Last edit: by zephyrin.
i was going to put some screws in my old tires once the new ones get here but then i found this idea:
i will probably make a mould so all the paddles are the same link to original thread what do you people think? |
so i tried the paddle tires but with hot glue, those didn't work the glue was too hard so it ripped off THEN i found these from a cheap tamiya clone, it looked like the aero avante df02 buggy but yellow
oooh spikes FLEX shot another flex shot look at the servo horn the original one had a different spline so this was the mone from the wild one but cut up and drilled close up of chewed up gears, be warned |
just made a horn for my car using my servo switch design but instead of leds its a relay driving a buzzer. its a pathetic sound for a monster truck jeep thing. imagine a vw beetle horn and times the stupidity of that by 10 i will post pics when the gears and tires get here
##update## i made a battery from an old macbook battery that i found at the tip 3s2p 5800mah Li-Ion and for free |
Woo the gears came today
moved the motor to where the velcro was, gave it a test run and its great the ground was wet and my battery wasn't full charge so no full speed, once i give it a clean and the sun is out, i will post pics and vids time to find a new wheel nut, it fell off when i was bashing it up my driveway the gears have very little wear after the bashing, if they were the old ones they would be destroyed |
