I should be working on a Reinforcing Plate soon which will fit over the front of the part A5 to stop it cracking.
Tamiya 0005300 / X10111 Thanks Bob @ Model Build www.modelbuild.co.uk |
bobzy20 if you manage to manufacture one please put me down for the first order pm me and ill paypal the money over as this will enable me to rebuild my thundershot
If you go ahead with it, can I suggest using say 20swg stainless, not aluminium - there's a lot of leverage trying to splay-out those lower suspension pins, (Enough to bust resilient plastic), so I suspect thin/soft ally won't be up to the job.
From memory, there are 2x screws in the front of A5, ideally positioned for the securing of said reinforcing plate
Thanks for the notes, I will look into it.
Here is something I prepared earlier. Thanks Bob @ Model Build www.modelbuild.co.uk |
Last edit: by bobzy20.
Tamiya 0005300/X10111 - Thunder Shot Part A5 Always Cracks?
Any of you guys have a Thunder Shot, Thunder Dragon, Terra Scorcher or Fire Dragon and are fed up of buying the A Parts over and over to replace part A5? I will hopefully have a solution very soon with a Steel Reinforcement Plate that fits over the front of part A5 to stop it cracking. I have put them on eBay as a pre-order: www.ebay.co.uk/...0630213543 You can follow this on Tamiya Club also: www.tamiyaclub....opic=67514 Thanks Bob @ Model Build www.modelbuild.co.uk |
Now in Stock:
www.ebay.co.uk/...0748583054 |
