Hi guys.
Just wondering what the best length shocks are for all around on the Pumpkin/Lunchbox above? I'm thinking about the Ansmann aluminium shocks but the non adjustable ones. I like the truck to sit neater on the front shocks so there is a better camber for some flat road tyres (Modified Road Rage 2's, Proline). Would 75mm be best or can I fit shorter 55mm? I will get around to doing the 5th shock mod and will use a 55mm when I do this but I would be greatful for any hints. I did have a search but the results didn't come back with many size guides. Thank in advance. Rob |
In have 80mm shocks on the front of my Lunchbox & it has the usual camber on it at full extension ... doing some quick compression tests suggests 75mm would give neutral camber, 65mm would give you silly (F1/BTCC levels ) camber. 55mm would be far too short & just wouldn't work.
Perfect.
75mm it is then along with some fixing parts. Need to mark up and dig the dremmel out to prep the gear box/axle mount for the 3rd shock. Cheers |
The shock mount braces (part BS1, #9805082) are provided within the shaft parts bag #9400296. They should be still available due to the Lunchbox and Midnight Pumpkin re-releases. Take a look at the Lunchbox manual (p. 17) to see how the oil shocks have to be installed:
www.tamiyausa.c...t-id=58347 Runner:
Sand Viper
Mad Bull
BMW Z4 Hatsune Miku
Kyosho Sandmaster EZ
Project: Hot Shot, Holiday Buggy 2010 (narrowed), Monster Beetle, Super Fighter G, MINI Cooper S 2006 Retired: The Hornet Still NIB: King Blackfoot
Last edit: by GregM.
Other option is some of the various
suspension stays at RCChannel.com
The following user(s) Liked this: vardypeeps
good tip the #9805082 cost 3,50 and the bag with 3 pairs of the same braces 'only' 7,80 and comes with the wheeliebar as 'extra' |
Thank you again! small typo with the Midnight Pumpkin ref number by me too.
Thanks, I've rectified this in my inital post. Runner:
Sand Viper
Mad Bull
BMW Z4 Hatsune Miku
Project: Hot Shot, Holiday Buggy 2010 (narrowed), Monster Beetle, Super Fighter G, MINI Cooper S 2006 Retired: The Hornet Still NIB: King Blackfoot |
