This mr. E (not the one adressed earlier) is looking forward at least. Awesome-o.
Especially since I'll most likely be needing another set soon. Still got a couple of those templates as well. 35 degrees angle for correct perspective, right? |
Nice materials. Are you sponsorised by rothring? |
Ah, the days of PROPER drawing....
I spy some nice Rotring kit in there too (Think I've still got mine somewhere) Got all excited about "Vintage CAD", was interested to see what you were using - I used to use "Concerto", a DOS-based drawing package from the late 80s/early 90s, & to this day it was far superior to AutoCAD, even running on an old 286 PC! I'm not after anything splendific for the mount sketches, some scribbles on a scan of the manual would be fine, I just need accurate numbers for the important bits (eg where bearings fit etc)
Think I started with Autocad on DOS or WIN3.x, we did have somekind of mainframe CAD at our mechanical engineering college. (and a CNC lathe, now i wish to be at that school again )
Did manage to get some sketching done. 1 rear gearbox mounts (2x) 2 front gearbox mounts (2x) 3 steering mount (2x) 4 J12 replacement (1x) 5 wing mount (2x) 6 front body mount (1x) 7 saddle pack battery post (4x) as you can see I tried to keep them all in the same style could be supplemented with the damper spacers. will have a go at the measurements later this WE |
#7 is a bit of TF and a bit of TRF501
stabelizer would mean metalsheet work, that does not fit the program for the mount parts (thats all Lathe) other thing I have in mind includes lasercutting (a rere motor mount for Willy M38 so a sportstuned might fit) |
