rc switch kits from olds servos 10 years 8 months ago #24264
you may have read my hsp warhead brushless build and saw that i have made an rc switch from an old servo
you all will have an old servo with busted gears lying around the place
i have a board design for kits so it will be easy to make
rc switch ( click to view in 3D )
should i make these kits and sell them? i just designed this in a few minutes the next versions will be smaller
i will need some money to get started as well i might do this like a kickstarter thingy
Last edit: by zephyrin.
rc switch kits from olds servos 10 years 8 months ago #24267
  • Edou
  • Edou's Avatar
  • Away
  • Hopping Mad
  • Hopping Mad
I think it's a great initiative. B)
A while back I looked around for a simple switch module for the lights on my third transmitter channel...
But backed away because of the prices at the basic level even (several dozens of euros).
If you can make it more affordable, I'd be very interested.
In any case, I can really appreciate the clever stuff you've been into. :y:
The following user(s) Liked this: zephyrin
rc switch kits from olds servos 10 years 8 months ago #24280
they would bee good to have im just thinking of the prices
10 boards $15ish with postage
caps $3 ish
diodes $3ish
headers $2ish
so i would sell the kits for around $5
update!!!!!!!!!!!!!!!
i checked the prices
caps + diodes $3 don't know the postage
board + header + postage $15 ish
rc switch kits from olds servos 10 years 8 months ago #24284
UPDATED VERSION
i added a voltage regulator so you don't blow your leds
i couldn't find cheap regulators so i added a pot so you can adjust it
eagleU01.zip ( click to view in 3D )
rc switch kits from olds servos 10 years 7 months ago #24345
a great idea, good luck with it. You can also use a 4013 chip (example here - www.laureanno.c...tekmod.htm) if you don't have any old servos available, but you need some other components so its not as cost effective,
regards
Johann
rc switch kits from olds servos 10 years 7 months ago #24360
who hasn't got old servos lying around the place?
they don't need to have busted gears, you could use stock servos from rc cars
i could use a chip but this way is probably the easiest and cheapest
rc switch kits from olds servos 10 years 7 months ago #24366
agreed, using a servo is much easier. Also what I find odd is the ic chip used in the servo is quite often dearer to buy than a servo. I tend to go and make it all only because I like to tinker (and I don't have to make many!),
regards
Johann
rc switch kits from olds servos 10 years 7 months ago #24368
  • Edou
  • Edou's Avatar
  • Away
  • Hopping Mad
  • Hopping Mad
I'm gonna be very interested in a switch like this and will be keeping an eye on your updates. :y:
rc switch kits from olds servos 10 years 7 months ago #24377
cool
i will keep tweaking the board design, when i get it perfect i will get some sent off and made then i will sell kits the prices might be like this:
  • blank board, no parts $2
  • board with parts $5
  • board with parts soldered on $8
  • everything like with a servo not made $10
  • everything like with a servo made $13
those are just rough estimates once i make the kits i will know for sure. these prices don't include postage but they are small so postage will be like $3
with the servo ones i might use this servo
not sure if it has enough power though
rc switch kits from olds servos 10 years 7 months ago #24379
slight update
  • rounded the edges
  • added a few more plugs for lights and/or relays
if you have any sugestions tell me :)
i might get rid of one of the diodes, my one works fine with only one
Time to create page: 0.202 seconds
