I recently picked up a NIB rere Hopper for $45 at a flea market. Very odd kit. Came with an MSC and ESC and the chassis is molded for a hump pack but it has the Tamiya roof sticker and not the Weber one.
I have put the chassis and MSC away and ordered a proper rere chassis. On to my re-working. Decided it needs monster power so in went a 4300kv brushless. As we all know Grasshopper handling pretty much sucks. I installed Hornet rear suspension and it helped hold the power to the ground but the steering still lacked. Enter the CRP FX-10 front end kit. I could only find a handful of pics of a completed conversion. So there was a lot of trial and error. As it comes it's not a bad kit, just not made for the Grasshopper. Only minor chassis and body trimming was required to make it fit. And a little trimming on the mounting base. The big catch is mounting the shocks. I had a pair of mini CVA's, too fat to fit without removing too much plastic. Ok on to some RC4WD 70mm dual rate coil overs. Almost there but still too fat. I ended up mounting the shock bottom to the spindle carrier. The upper arms are also waaaaaayyyyy too long. 4 ball ends and some 4-40 threaded rod later and the wheels are upright. Road test to come. |
I think you probably got your balljoints in the "wrong" holes ... remember these kits aren't made specifically for the Grasshopper, so some on the fly remodelling is necessary. I tried one of these kits on a Lunchbox & never really got it right, so went back to stock I see you've also mounted the lower ends of the shocks on top of the knuckles rather than the gaps in the lower arms ... not a criticism, just an observation Great score on the kit BTW |
The shocks rubbed the chassis and I didn't want to trim any more off of it so had to go with the next best choice. Actually works really well. It now handles corners with a little authority. But the badword end still bounces around on asphalt. I'm thinking it's as good as it gets without a ball diff, if one even existed.
