Hi
I have just bought a Tamiya Super Stock Motor. I run a Mtroniks AutoSport 20 Turn ESC. Will this electronic speed controller be fine with this motor. I understand sometimes the Super Stock motor can make an ESC cut out! What is the best pinion to use? I should add this will be going into my DT-02 chassis. Thanks in advance. |
Thanks for reply. I was hoping the Mtroniks AutoSport 20 Turn ESC would be o.k as upgraded this from the Tamiya one in kit.
What size pinion would you recommend for everyday use? |
No too much choice on a dt02. 17 or 19 teeth.
