Jonny I didn't know that your... was named willy... |
Last edit: by stingray-63.
Dammit! I've gotta get a Wild Willy just so I can join in on the jokes... |
Yep, I recommend you get you hands on a Willy ASAP |
Didn't we have a thread for the best quote's about ones Willy, think some of the above could be considered
Have to get some work done on my Willy too so I can make his head turn, that project has been in a drawer for too long. |
Sounds painful or expensive. |
So I too went for some hot glue and put a socket screw in it, that did the trick and maybe have to use an o-ring to get the head facing in the right direction. Beermeister, did you have to make a hole in your seat so your Willy would fit? |
Used the Tower Pro version, looks to be the same dimensions. Used a 3x.5 bottom tap and a drop of epoxy. The top end of the screw got blue thread lock to keep his head from flopping or being too tight on the body. |
