Been doing some work on the body ...
Decals were pretty nasty & I didn't fancy my chances of getting a new set, so peeled them all off & stuck them on white card so I could scan them. Well, I say "stuck", I'd guess at least 75% of the adhesive stayed on the body & had to be cleaned off Painted the body using the 1/2 can of pactra that came with the car ... including the windows as they were too scuffed up to want to leave them visible... Some scuffs are still visible: I redrew the decals, printed them out on white & clear self adhesive injet vinyl, cut out the white ones & clearcoated the lot: I wasn't sure about the Audi rings logo, so cut out a pair in red self adhesive vinyl: Also drew & cut out a set of SA vinyl windows & surrounds: Body is finished, wing is off my Tamiya Citroen Xsara Rally shell - I'm not that sure about it, but at least the spacing on the pillars was right Chassis has a way to go yet |
Awesome work on the body looking great
Last edit: by tamiya nut.
Stripped the paint off the chassis tub & it still looks pants ...
... a bit of sanding, ditto Rear diff components: Back gearbox complete, starting on front ... getting a feeling of deja-vu here, but I've nevr had a TA-01 chassis before ... I'd need to check, but a lot of bits seem very like a Pajero MTW? Front box built... Shock absorber bits; note the two sorts of spring, two sorts of spring retainer, and three sorts of rod end Lukily my spares pile provided the correct bits... ... |
My spares box also provided some bits for the steering setup ... it's still a bit of a lash-up, but at least now it's all a correctly fitting Tamiya lash-up In fact, everything is feeling pretty taught now the correct fittings and fasteners are being used, so I went back & changed the motor for something with a bit more pep |
Way ahead of your there I had to make a new one out of welding rod |
Black painted tub - it's not "right" but it does match
Front end still isn't right - I had to fit the balljoints on the uprights underneath to stop ludicrous toe out when the shocks compressed ... Bloo hubs ... I would have liked to fit the shell lower, but it's a compromise with the mismatched wheelbase, and the inaccurate way the mount holes have been drilled |
