Grasshopper ll tire alternatives 3 years 5 months ago #62574
  • kapo723
  • kapo723's Avatar Topic Author
  • No Guts No Glory!
  • No Guts No Glory!
Hello everyone!
I was hoping to see if anyone knew of alternative tire options for a Grasshopper ll 1.7" rims? I have 2 that my boys are still running around and they eating up the tires as they run on asphalt mostly. Any help would be greatly appreciated!
Grasshopper ll tire alternatives 3 years 5 months ago #62579
Hello and Welcome, So a little trick is you can stretch fit Tamiya Sand Blaster tyres to these rim's :) Alternatively you could buy a couple of sets of Wild One rims and tyres, They are a direct fit so will bolt straight on :)
Last edit: by AndyAus.
Grasshopper ll tire alternatives 3 years 5 months ago #62581
I used the Tamiya hex adapters for the Frog (53913) on my regular Grasshopper so any wheels that match the DT-02 can be fitted.
Grasshopper ll tire alternatives 3 years 5 months ago #62594
hi i like the wild one tires on it
u could put a smaller motor in it saves the tires for very long time
if u did that it would drive 2 times as long too
Last edit: by spannerman3.
Grasshopper ll tire alternatives 3 years 5 months ago #62595
For non Tamiya, RC4WD also make assorted tires for 1.7" wheels if you fancy something else...
Grasshopper ll tire alternatives 3 years 5 months ago #62598
  • kapo723
  • No Guts No Glory!
  • No Guts No Glory!
Thanks guys! Found a bunch on RC4WD as you mentioned, we will have fun with them for sure! Any thoughts on the front tires?
Grasshopper ll tire alternatives 3 years 3 months ago #64023
you could go for wild ones front tires on it
are u going to run on road or off road?
