About some detours, and oddly enough he came into my possession, the search for parts was partly right difficult, but now it can begin.
Of the overwhole condition of is consistently as well to describe, the car is completely, a servo and even the original mechanical speed controllers are installed. Of course waited many scratches the underbody, and also the body has one or the other scratches/cracks. Even the most defective or missing driver is present The Chassie could be further stripped The cage is (for the time) sensational has been implemented, and seemed very Scalig See also the shock absorbers as the originals of 1985 from A look at the details of the front axle The Chassie would undergo an intensive cleaning, only using detergent and then were still existing adhesive that remains with Spiritus away. When cleaning was then unfortunately not all to a small crack in the Chassie found. The vitreous was cleaned, and so good it was glued to shock. Since the Chassie else a couple scratches has, i think i need to think about something else here. The cage was also thoroughly cleaned, also here are of course clear narrowly missing in the plastic had been present Consequently, it was pre-ground, smoothed over and finally primed This was followed by three layers gloss black During the drying of the cage's, were the two aluminum ribs. (the serve to reinforce) polished In the interplay between the parts, a very smart thing as i think The dampers were also cut ... ... And of course once again cleaned and polished. Here again the comparison to the left of the "only" purified dampers, to the right of the purified and polished dampers After the Chassie again was produced/restored it could go further The holder with their new battery compartment cover were mounted After the front Damper stay were cleaned and refreshed you were assembled The front axle has been cleaned, refurbished and somewhat straightened Also the mounting were cleaned Once again everything was mounted The GFK reinforcement of the front axle was cleaned and primed Then, as well as black painted and assembled It then continued on the rear axle Now it was time to mount the cage The front axle has been further stocked The first finished dampers could be mounted on the front axle Then it went to the gearbox Everything has been disassembled, cleaned and then again with ball bearings and stocked with V2A mounted and screwed Now it was time again inculcate the transmission The parts of the power transmission have been purified, with new ball bearings stocked and mounted The bracket were also revived and mounted In order to avert the engine the it was something i've been trying, until i wanted a nice brushed motor, am now but because of the optics but with a nice brushless motor landed All red plastic parts were cleaned After the cleaning was then wrapped everything in shiny black and after and after mounted on the model, just as the first finished rear dampers The second shock absorbers of the front axle was ready ... ...And, after the glands were grown reconsindered In my parts boxes I am still on a new eco II Servo encountered towering above which in the time of the Wild one fits and immediately was mounted The original front tires were cleaned, refurbished and then click on the new aluminum rims are reared and fitted with ball bearings The new rear tires were also drawn on aluminum rims Then, the new rims time sample sit at the model The first decals were in the assembly of the second rear shock absorber appropriate The engine was also enhanced by Decal The new body was as the next in the series After the cutting and drilling the holes, it is expected to Seat tests According to the orders of the black Lexan paint was first mounted the roof ... ... Then the Chassie disguise After the body has now taken place had the chrome sticker affixed were In the port went there to the manufacture of lamps, the output parts tree was disconnected The lamp coverings were painted yellow and with the then typical Daxlighter smileys fitted The housing were painted black Then followed the assembly |
Last edit: by fabulescrawler.
I can only say this is a great build thread with all the detailed pics. And a fantastic result!
Too bad the accompanying text is only in German. Not a real problem for me because I can understand but most readers on TB probably won't. Still - one of the slickest builds ever... |
Thanks Edou! My posts will be translate in english soon.
The translate is done I hope it is ok?
