Restoring Countach 58005
Definitely 059 parts. I've just stripped down 3 959's and your parts look the best part of 059.
<p>Current projects:</p>
Yep it is a 959 rebuild small differences between the two but this one is a 959.
Cleaned all parts and repaired a few broken ones. First step the steering mechanism; Too bad the E11 part was missing lucky for me i had a e tree almost complete on spare from my first 959 resto, but no E11 part there either... So i took a double E8 part and levelled it, then modified and clipped a E7 part for the hight. Not used the 3x8mm screw but instead used a 3x27mm screw with 3mm nut, works like a charm Next rear gears Front gears Rear Replaced the c-2 parts with new ones i had from first 959 resto... Cheers, Bram Restoring Countach 58005
Last edit: by BramMeijer.
