Ok, hitting the gas and blocking is defenitive not a good idea. The cables gonna get very fast hot but yeah, now with the 16T i think it's much better than before. I've done an indoor test. We have a plant pot here and i could move it with the 23T but now i can push it through the room
So now i need better weather, a bigger battery and also a better recharger. My one is a 1A. I saw a 4A from Carson (www.tamico.de/C...cer-606045) which can be used at 12V in car and also on 230V in indoor. What do you think? Is it a "could buy" or "don't buy!"? |
dont, and if you mean with bigger battery more amps like 5000 dont forget the longer runtime will make the motor and such hot so think to take a brake (or buy a small infrared temperatur measure thing).
better buy a battery with less mAh better with more umph (better discharge capacity). for charger I would rather take the LRP or an Imax B6 (but such said me myself am still looking for a decent NiMh charger ) pushing the pot around sounds ok for me with blocking I meant just for a second not untill its cooked |
The feature to use a 12V of a car is a nice one but ok, i'll use LRP. Carson is very cheap. The 2,4ghz remote is ok but feeling not very nice.
Maybe i'll buy a second one on the 12V to load battery anywhere. |
Edou, i need the 12V for in-car but it has also this. Nice
'Cause i want to use the FRP also for touring car, i want to buy a used ta02 car, the Alfa Romeo.
But i want to build up a ta01 touring car with it and now i have to know where exactly the diffcerence is. - The tube is shorter - rear gearbox is longer - rear arms have different layout I saw that the front arms are also longer but it is quite weird. Here is a good info on TC: www.tamiyaclub....83&id=2193 So what do i have to get to use the Alfa as ta01 car? - Rear arms - front arms - ta01 gearbox is already there from the MR Anything else? |
the front and rear gearboxes of the TA01/02/DF01 are all the same size.
tubs are 2 versions TA01 is the longer one then there is the collection of different F&R arms. I might have several short/street arms lying around for TA01/02 |
Ah i see. It's not the gearbox, it's just the rear arm which is reaching out to the back instead beeing linear to the mounting.
Would be nice if you can sell me the parts which i need after buying the car (hope the price won't be to high). I don't want to use the alloy parts for the arms. |
You'll need to replace the main drive shaft for that of a TA01 as well.
Edit - this is a good page too : www.tamiyaclub....opic=61592
The following user(s) Liked this: funkindemup
