Well, the first step for the restoration is the stripe of the car.
These are the bare chassis and top body. As you can see the look seems good but only seems, they are not. With a closer look you can see the real problems of this car. The chassis is broken in many parts in the front end. This is a classic Hornet, Grasshopper, Striker breakage on the 3th bumper screw. As you can see here has been badly repaired. I should be a bit bored that day. Another problem under the bonnet. You can see the melting due the chemicals. The next step will be the stripping of the paint. Max |
HI!... MAX too bad you weren't closer to me. I could throw that in my glass beading cabinet with the fine glass bead and clean that right up for you. I do chassis and wheels all the time right before I paint them. Makes them look almost like new and makes the paint better adhere.
The deeper you dig, the worse it gets
I'm sure it'll come out well in the end, but at this point I really don't envy you ... |
Ehi H.P., thanks for the offer, I don't know where are you located but I'm in Italy so it will be very difficult have a meeting to try your beautiful glass bead cleaner. Nobody knows how I will need it
Max
HI!... Canada, so quite far away. lol |
Wowsers this chassis has some kind of life Reviving something in that condition is where the satisfaction comes from though
The following user(s) Liked this: Kontemax
Striker is one of those wierd cars you dont like at first but then it grows on you over time i like these when finished well
