Dear fellow RC Enthusiast,
I am restoring a beautiful SRB chassis. I cannot find a motor that fits, since there are 2 pins and tongue (key?) located in the motor mount that would require a 540 motor with only 2 round shaped "slits" on the front end, whereas all motor I could find have 4 slits. Any idea which motor could fit and where I would get it? Thanks and cheers MetalMaxx Attachments: |
Last edit: by Jonny Retro. Reason: inserting pics :)
I had no problem installing the 540 size black Sport tuned motor. Hope this helps.
I’ll check mine.
I’d have thought a standard 540 would fit no problem. But I guess it’s one of those things where you’ve got so many different variations out there. I’ve had problems in the past with the odd motor being very slightly too wide. |
Maybe a johnson? I had this matter with mine but I had old silvercans.
Hi MetalMaxx,
So after taking a couple of gear boxes apart, the first one was a MK1 gear box. It doesn't have that curved tab. So I went for a Mk2, bingo it's the same as yours. I think what the issue is that your thinking 2 bolts need to go through the gear box and into the holes on the motor. But I don't think that is the case. The plastic case at the back of the motor holds it in. The instructions ask for 2 10 mm hex bolts, these wouldn't be long enough to go through the metal gear case and have enough thread to hold the motor. So a standard 540 should fit, but the holes don't line up. I hope this helps. Al
