How many times do i have to repeat that my MR shell doesn't have a noes anymore?
Thanks for answers! |
The following user(s) Liked this: funkindemup
I've heard that this was caused by a fat french guy
Crap, those GPM motor mounts are really becoming a nuisance.
Plan was to take off the silvercan on the Humvee to replace it with the CR-Tuned. But yet again one of the pins got stuck in the gearbox... Apparently the thread lock sipped through the wrong way on one side. Luckily I solved it this time with regluing (using J-B Weld steel epoxy) instead of mutilation. From now on I will fuse the parts permanently this way before fitting any alloy motor mount again. If I don't go for a one-piece specimen like waterbok's... Anywho, moving on. Had a plan for a Mark II gearbox bracket for a while. As a reminder, this is Mark I : Using the wrong side of my brain, I placed the hole nicely in the middle last time : But forgot to account for the bit on the side so that actuallly makes it 2mm off. A good reason to use my drill standard (not owning a vice for it yet) : Besides a more accurate fabrication, I'm adding a spacer and washer : Spacer was ordered for this purpose - to perfectly match : On the left - the reglued motor mount while drying... Working on that rear gearbox, I noticed a small crack on another screw hole. And I killed the thread on the one remaining one (there's only three screws on top). The gearbox is from the original Manta Ray I started this thread with... So I'm gonna use some more steel hardened epoxy here and there. |
Maybe you've done too much torque on the screw to fix the gpm mount at the chassis? You can use a needle-nosed pliers with some cloth to loose it without damaging it.
Btw, want to see some horror-pictures? Beware, you have to have a strong stomache img.photobucket...C/mrp8.jpg |
Last edit: by funkindemup.
