Re: List of Cars / Motor Pinions 12 years 2 weeks ago #8746
have also collated the part no / teeth / pitch info so far:
part # teeth pitch notes
3510001 13T ?
3510003 15T ?
3510004 16T ?
3510005 20T ?
3510006 18T ?
3505014 10T 0.8 17mm long brass type
3515001 13T 0.8
3515002 14T 0.8
3515003 15T 0.8
3515004 16T 0.8
3515005 17T 0.8
3515006 18T 0.8
3515007 19T 0.8
3515008 16T 0.8 ?
3515009 16T 0.6
3515010 17T 0.6
3515011 18T 0.6
3515012 19T 0.6
3515013 20T 0.6
3515014 21T 0.6
3515015 22T 0.6?
3515016 23T 0.6
50354 - 16T & 17T AV (0.6mod) two pack
50355 - 18T & 19T AV (0.6mod) two pack
50356 - 20T & 21T AV (0.6mod) two pack
50357 - 22T & 23T AV (0.6mod) two pack
50477 - 24T & 25T AV (0.6mod) two pack
84181 17T 0.8
84182 19T 0.8
I've had a second look at a few. No real logical order to them and for different models.
Some still need more research but I guess I'll come across them again :
3510001 16T (? mod)
3510002 17T (? mod)
3510003 15T 0.8
3510004 ?
3510005 20T (? mod)
3510006 18T 0.8
3515015 22T 0.6 - confirmed
3515017 21T 0.6
3515018 14T 0.6
3515019 20T 0.5 (!)
Summarizing the additional part numbers found :
53063 12T/13T HP steel pinion gears (0.6 mod) two pack
53064 14T/15T HP steel pinion gears (0.6 mod) two pack
53080 18T/19T steel pinion gear set (0.5 mod) two pack
53081 20T/21T steel pinion gear set (0.5 mod) two pack
53082 22T/23T steel pinion gear set (0.5 mod) two pack
50238 13T/14T buggy pinion set (0.8 mod) two pack
50239 15T/16T buggy pinion set (0.8 mod) two pack
50240 17T/19T buggy pinion set (0.8 mod) two pack
Re: List of Cars / Motor Pinions 12 years 1 week ago #8894
First list (models 58051-58100) finished!
I could use some information on the module of the pinions used on the Racing Masters and F1s 58068 and 58069. :y:
My suspicion is they are the ancestors of the 0.6 mod AV pinions...
3510001 16T
3510002 17T
3510004 18T ?
3510005 20T
50174 Aluminium pinion gear set 16T & 17T (0.6 mod?)
50175 Aluminium pinion gear set 18T & 20T (0.6 mod?)
Re: List of Cars / Motor Pinions 12 years 1 week ago #8904
Jonny, do you mind if I also fill in the gaps in the first post? :cheer:
Could still use some info on the RM pinions... that'll complete the first list! :)
Re: List of Cars / Motor Pinions 12 years 1 week ago #8905
NP ... Might be better if you edited it right down to something like "refer to second post" though :) ;)
Re: List of Cars / Motor Pinions 12 years 1 week ago #8913
Thanks, I'll add an extra line in the beginning that other details can be found there. :y:
Started on the list for the first 50 models too. Basic layout for that is finished. :cheer:
Re: List of Cars / Motor Pinions 12 years 1 day ago #9149
Hey guys, some help would be appreciated here...
I noticed the SRBs and the cars using the Wild Willy gearbox have 0.6 module gears.
Are these pinions very specific or can they be replaced by regular specimen?
Other than that the pinion is put on backwards on the Super Champ. :huh:
Second request - anybody have info on the module used on the Racing Masters?
That would really be a step forward in completing the data.
Interesting... overlap for the Ford C100 indicates that aforementioned cars are all using the same module.
Tamiyabase 58033 spare parts listing
Re: List of Cars / Motor Pinions 12 years 1 day ago #9151
SRB pinions are just "regular" pinions, there's nothing special about them :huh:
Wild Willy M38 (& others that use the same gearbox) have pressed on pinions that are the same overall length as regular pinions, but they're not turned down to make space for the grub screw - so the pinion effectively has much longer than average teeth.
Although you can get regular style pinions (i.e. screw down ones) with longer than average teeth, they won't fit in the gearbox due to their overall length ... so you're stuck with using regular pinions, and running on part of the idler gear rather than its whole length.
I don't see it as a problem though - other cars (especially the Frog/Brat) have really "short" spur gears & they're generally not regarded as the weak point of that gearbox, I've used a regular pinion in my M38 (not the one that's in bits, obviously - though that will get a regular pinion when I rebuild it), abused the car quite badly & it's not caused a problem ... although I haven't tried it with a hopped up motor :)
Re: List of Cars / Motor Pinions 12 years 23 hours ago #9154
only thing different at the SRB pinions is that the small one, 15T if i am right, is steel not aluminium.
also looking for Willy pinions that are the right lenght, was thinking of contacting these guys to ask if they have something fitting.
Re: List of Cars / Motor Pinions 12 years 23 hours ago #9155
Thanks guys, strangely enough this motor with "grubbed" pinions is listed as a spare part for all the cars mentioned :
Also very interesting :
58035 Wild Willy, 58036 Audi Quattro Rally, 58037 Opel Ascona 400 Rally and 58039 Willy's Wheeler all use the same gearbox. But the Wild Willy has a different gearbox plate and a 15T pinion. The other cars use 18T.
I'm discovering nice details while going through the spare parts listings...
For example that the Frog shocks are a racing hop up for the Grasshopper!
I received some from Louisbaby a while ago... B)
Re: List of Cars / Motor Pinions 12 years 23 hours ago #9157
58035 Wild Willy M38 15T 0.6 mod (Thanks Jonny Retro)
58036 Audi Quattro 18t x 0.6mod (thanks eddrick)
58037 Opel Ascona 400 Rally same as 58036 18t x 0.6mod
58039 Willy's Wheeler same as 58036 18t x 0.6mod
35, 36, 37 and 39 all use the same gearboxcasing.
35 has two versions of the same gearbox with 15T layout, some gears, bearings and axles were changed in the lwb version
36, 37 and 39 have a different gearbox plate and layout to fit the 18T setup (idler gear is a bit off center)
Time to create page: 0.131 seconds
