Blimey, 5 weeks since I last thought about doing anything on this
Not much of an update, but I've stripped the KBF chassis down to clean & tidy up the mods I did in the past ... Pajero wheelie bar fitment just needs a few edges tidying, but the upside down & centralised steering servo needs the brackets re-making properly in aluminium. Gearbox on the other hand doesn't need any work internally |
Spent some time making things clean & shiny ... replacement aluminium brackets for the upside down servo mod have gone from being as rough as a badgers behind to positively blingy; windows (on the right) were polished with the Novus 3-part set; the 5 missing brass bits were made by machining down ones with heavier bases; everything else has been through the ultrasonic tank.
Still need to sort the roofbar lights & make a sunstrip, but I'm just about ready to put this one back together again |
After a false start (putting alloy spacers in the gearbox instead of the brass ones ) & lots of long breaks I got the chassis back together ... I couldn't remember if I'd had this car completely apart at any point before - I guess not as there were sprue burrs everywhere, and a hole missing on the chassis...
Started dismantling the Bush Devil chassis:
Bumper needs replacing (I might just use a Lunchbox one instead), definitely needs some sort of underguard... Note routing of servo wires I don't think they've been there for long... Wheels needs a skim & some tyres... Motor needs resoldering... Antenna holder needs replacing... Resistor wiring needs some attention, resistor itself needs replacing: ... |
