That's all been fitted, pretty awesome. I'll take some pics later (before I get it all dirty again).
Knuckles came from RC Damper... and they are now the weakest link in the chain. Bearing tolerance on them is quite horrible. I even start to think they're GPMs that didn't make the cut. So that'll be something to change (once more) in the future (not throwing any more cash at it for a while). |
Before :
All new black chassis screws : This was looking a bit messy : Replaced all nuts with anodised alloy and just about all screws. All the bits in the steering linkage as well - and added dust covers on the ball ends : And some subtle aesthetic differences on the rear (just need some smaller rings) : |
Front end was a mix and match :
Just a little nicer in every way (even the shock spacers) : Fluorine ball ends, Tamiya king pins and dust covers for the steering, plus a black alloy nut for the servo horn : King pins looked too shiny so I aged them a bit (fine sanding and caustic soda) : Even the spacer is black now - and 0.5mm smaller to create some more room : Left ball end was tightened after I saw this picture. No more blue on blue or golden ball ends : Not too shabby, we're actually getting there after a year or three : |
Nice one! No problem with sand with the open brushed motor and with the axialgrease?
Definitely the most dirt gathered inside the wheel axles (dogbone side).
That's why I don't grease them to begin with... Got a good clean with a brush altogether though. Shook out the rest (motor as well). |
So I'm sure everybody has read every single thing that happened during the past seventy pages.
Anyway, I started out with this Hummer using both 70mm shocks rear and front... Then I thought they were a little long in front and wanted to try 65mm. Yeah Racing didn't have those so I bought a complete 60mm shock set - and used only two of them : Now when I wanted to put the remaining pair of 60-70mm up for sale, I realised I had been a rookie earlier in this thread! I could have avoided getting the shorter set (although they matched pretty well) altogether and just space out the shaft by 5mm. Which is what I will be doing this time around (and raise the suspension a little) : Recycled (slightly used and deanodised) parts.... Gonna add some TRF oil seals while I'm at it, since they are the same size. |
Uuh, very Hard setup for the Hard terrain. Use soft Oil and Soft setup
