Somewhere a cross-channel ferry is missing a section of lower deck flooring
it is flooring jonny,rubber floor tiles from a job i did about 10 years ago.
i was refitting the tardis in 1985 i never noticed before but those rubber tiles were made by pirelli jtf |
Last edit: by jon_the_fox.
If the size of your images are to large and I think it's only 8 pic'd per post. www.tamiyabase....Itemid=476 If you can't fix it with a hammer, you've got an electrical problem mate
cool thanks andy,im happy with puting 6 or 7 at a time on its no biggie,its when i go for 8 it boots me off :y
onto the next step after an epic upload fail the fox steering is a thing of beauty i think,its unique in its own right,not everyones brew but i like it but not the most stable steering set up ive seen i imagine it would break easily after a moderate knock in the right place, the nova fox steering set up seems to be a lot more stable and secure,but as tamiya nut said re re's do lack pedigree and some can be a lash up to fix old problems,either way i still prefer the old fox steering set up.just my humble opinion |
onwards and upwards
fixing the msc to the servo,one word.WOW a quick test again,when i tested it like this it picked up 3 speeds,however when it was assembled i only got one speed and that was flat out??? i was a bit worried at first because i thought i was missing the ally spacer so thought i had to make one,but i had a quick look see in my rubber parts bag and found this |
That's with the resistors fitted in both cases? Because you seem to have "lost" them in the later photos
The following user(s) Liked this: jon_the_fox
IIRC the GRP plate can be fitted either way up - if you fit it the other way up, the way it's bent with age will help with contact rather than hinder it |
