Just a quick question.
When using grafitti remover do you brush it on, and leave it for a while, then take a rag and rub down? I have a few items that I need to get some paint removed. Caustic soda and Dot 4 brake fluid have to be filled on a can or something, and then delivered at the recycle center after use. I have no storage place, so grafitti remover seems more logical to me Richard |
Hi Richard, The brand I’ve used was “ Mykal - De solv it graffiti remover “, which comes in 200 ml spray cans. I know Rob and others have used “ Graffiti go “, which looks like it’s also a spray. ( 500 ml - better value for money on cost ) I put the items I’m cleaning in a box, spray and then I leave it until I see the paint start to blister. Then I put it in a bowl of water with a bit of washing up liquid and use a toothbrush to scrub. You will probably have to repeat a few times, it really does depend on what’s been put on previously and how much. To finish off I tend to go in with a scalpel and scrape off any stubborn, awkward bits. If it’s a body shell I usually use some wet and dry as well to rub/sand the paint off. Then when your done, tip the bowl down the sink. Hope this helps, Al I haven’t tried Graffiti Go, but I will be giving it a try next time. |
Last edit: by Al.
That's awesome! Thanx for the explanation Not many sells grafitti remover around my area, but I found one shop yesterday that have them at 15 quid for a 400ml spray, that's good price in costly Norway |
The brand is Duxola, don't know if it is norwegian or not..
It don't say if it's plastic safe or not, so sent one of the shops a mail and asked if it was ABS and Polycarbonat safe. Hopefully it is. Found a shop that sells them 1 quid cheaper than the other
Big sigh of relief, I’ve been hoping to pick up the final bits for this FAV without having to buy a new parts tree just to get a couple of bits.
Fingers crossed, but just won an auction for a pile of Wild One bits. Amongst which are some rear trailing arms. Hopefully good enough to finish off this build. |
I’m waiting on the last few bits to arrive to finish off the FAV.
But I couldn’t resist getting this out of its box in the garage for a photo. I like this chassis, judging by some of the great examples out there, there’s a lot you can do with it. I bought the Wild One over a year ago. It’s probably the most tidy and complete used car I’ve bought. So I’ve never felt in a rush to do anything with it. But it’s nice seeing it next to the FAV.
Last edit: by Al.
